by dezsoe » Thu Mar 28, 2019 5:55 pm
AXBB has common ground (0V), so it will not work this way. You should use a 24V relay to short your wires. See the AXBB manual how to connect a relay to O2..O8. (O1 is reserved for charge pump, but it works the same way.)
