Button not visible
Button not visible
Postby mr_cg » Sat Mar 23, 2019 5:20 pm
I am using stock Screenset from Stepcraft.
Why i try to run loaded gcode i get window for "initial movement preperation".
Unfortunately the buttons below are not visible and i do not know which button to press.
See screenshot attached.
mr_cg
Re: Button not visible
Postby ger21 » Sat Mar 23, 2019 5:33 pm
Do you have Windows set to use "Large Fonts", or more than 100% font size?
Postby mr_cg » Mon Mar 25, 2019 7:46 pm
By chaning the font size from 125% to 100% to buttons are visible. :-)
It would be great if the windows would be scaled correctly independent which font size is used.
Only because of UCCNC i need to change the global setting now to 100%.
You can mark the topic as solved. Thanks for support.
mr_cg
