axbb wiring Laser
axbb wiring Laser
Postby joed54 » Wed Mar 20, 2019 4:13 pm
Hello
Can any one tell me how to wire a laser to axbb-e and how to set up uccnc software .
i have this laser https://www.ebay.com/itm/Engraving-Lase ... SwKA5b2GM-
and if this laser is only on /off or if i can adjust the power by pwm
joed54
Re: axbb wiring Laser
Postby dezsoe » Wed Mar 20, 2019 9:20 pm
If you use a separete 12VDC supply then connect 12V - also to 5V0 on the non-isolated outputs group of the AXBB, any of O9 to O17 to the laser Signal IN.
Postby ger21 » Wed Mar 20, 2019 9:45 pm
It looks like On/Off only.
Postby joed54 » Wed Mar 20, 2019 10:37 pm
Thx will test it out tomorrow :)
joed54
Postby cncdrive » Thu Mar 21, 2019 3:12 am
On/off, but they wrote 200kHz TTL with high speed isolation which means that you can switch the laser fast with the motion controller (with the laser PWM from the controller) and so you will see avarage power from the laser, or at least you should if the e-bay listing data is true. :)
Postby joed54 » Thu Apr 18, 2019 6:11 pm
Hello
got it working with a new driver from jtech photonics and all worked fine last night . but today when i give m3 s28000 my laser turn off and when i type m3 s4500 its on full power . my spindel works correct at the s command
any one got a clue ?
joed54
