Hi
Well this weird problem is still happening.
I have done another drawing with z set as up in fusion , which I definitely prefer.
This time I tried drawing the board with extruding -18mm instead of 18mm, to make sure everything was referenced from the top centre surface. Then I did a .5mm pocket. In the setup I used the same central origin position as in the drawing to avoid confusion.
Ran the simulation inside fusion which looked perfect, cutter started in the middle ran all around the board leaving a border and stopped, withdrawing the cutter.
Great I thought so once again I post processed it using the UCCNC option.
Well once in UCCNC it is again looking like it wants to chew right through the board.
Its like somewhere in between the two softwares it is flipping the z axis upside down?????
I don`t get why it let me cut a small test pocket which I created in exactly the same way.
Ollie
