Hi
I have got to the stage where I want to surface my spoilboard on my cnc router. I have managed to get the calibration, tool height probe and soft limits done.
So now I want to surface the spoil board. I have screwed on a sheet of 18mm to the table just slightly bigger than cutting area and I just want to take 1mm off all over to make it co-planer with the cutter. I have 25mm 3 wing bit for the purpose.
I have 2 methods drawn up in fusion 360, one is where I have done a 1mm pocket in the board which will just leave a small lip at the edge, the second is a facing operation but I am not sure about this as I have no room to fly over the ends of the board.
Anyway, I get to the bit where I am ready to export the Gcode to test in UCCNC and there is the choice of all sorts of machines or processors to choose from. Which post option should I choose?
My machine is a custom made one from 45/90 extrusion (Pictures here http://www.mycncuk.com/threads/11870-Ab ... hole/page2 ) I have a UC300 eth 5lpt, uniport v2 BOB, Kinco stepper drivers, nema 34 motors, 25mm Ballscrews X and Y and 16mm on Z.
Can you build your own post file specifically for your own machine? Not that I really want to get complicated at this point.
Or is there a better\simpler way to do a surfacing toolpath?
Ollie
