Macro Wizard / Form >> TextField Limit to a number range?
Re: Macro Wizard / Form >> TextField Limit to a number range
Postby Robertspark » Fri Mar 15, 2019 7:45 am
Thanks Dan
Yes there is a bit that you did not know as I was already limiting the technical characters to 2 via the max length property, and the numbers were purely integers (decimal point excluded from the char)
The bit that I am not getting is the "and just check for 11", as that is the bit I cannot seem to get.
Postby Dan911 » Fri Mar 15, 2019 10:06 am
Robertspark wrote:Thanks Dan
What I should of said is check for 10,11,12 and would of eliminated any confusion. if you don't care or want backspace to work remove !char.IsControl(e.KeyChar)
private void textbox_KeyPress(object sender, KeyPressEventArgs e)
            if (!char.IsControl(e.KeyChar) && !char.IsDigit(e.KeyChar))
                e.Handled = true;
          if (textbox.TextLength == 1 && e.KeyChar != '0' & e.KeyChar != '1'& e.KeyChar != '2' & !char.IsControl(e.KeyChar))
                e.Handled = true;
Postby Robertspark » Fri Mar 15, 2019 1:47 pm
Dan,
Thanks very much, I did not realise that the e.handled would be done twice and I've not used the *.index before for validation learnt something new thanks very much.
Postby Robertspark » Fri Mar 15, 2019 3:58 pm
Dan,
Thanks very very much, that code worked a treat!
Always learning something and always something to learn especially with code.
Postby Dan911 » Fri Mar 15, 2019 6:08 pm
Happy to help Rob, yes always something new to learn, I barely scratched the surface.
Actually looking at code it's not foolproof for 12 or lower, you would need another check for first digit to be 1.
Postby Dan911 » Fri Mar 15, 2019 10:18 pm
Hey Rob,
I'm sure you figured this part out but posting for others and for sake of completion. It does show a variety of ways to manipulate keypress for textbox.
Will only allow 0-12 in a textbox. textbox.MaxLength set to 2
            if (!char.IsControl(e.KeyChar) && !char.IsDigit(e.KeyChar) &&(e.KeyChar != '.'))
                e.Handled = true;
           if(textbox.TextLength == 1 && textbox.Text != "0" & textbox.Text != "1"& !char.IsControl(e.KeyChar)) { e.Handled = true; return; }
            else if (textbox.TextLength == 1 && textbox.Text == "0") { return; }
            else if (textbox.TextLength == 1 && e.KeyChar != '0' & e.KeyChar != '1'& e.KeyChar != '2' & !char.IsControl(e.KeyChar)) {  e.Handled = true;}
Postby Dan911 » Sat Mar 16, 2019 11:03 am
Playing with this with my coffee this morning and here's a more universal way for different amounts or needs.
if (!char.IsControl(e.KeyChar) && !char.IsDigit(e.KeyChar) && (e.KeyChar != '.'))
                 e.Handled = true;
                 return;
            if (!char.IsControl(e.KeyChar )&& textbox.TextLength == 1)
              int i = Convert.ToInt32(textbox.Text+ e.KeyChar);
                if (i > 12) { e.Handled = true; }
Postby Robertspark » Sat Mar 16, 2019 11:07 am
That is a better way of doing it imo
And was sort of what I was trying to do but could not figure out the syntax.
Thanks again Dan
