UC400ETH - best BOB?
Postby bpratl » Fri Sep 09, 2016 10:34 am
I'm in the process of changing from Mach3 to UCCNC and upgrading all of my electronics on my CNC lathe. I just purchased a UC400ETH controller and trying to decide between a PMDX 126 or a CNC4PC C32 dual port BOB. I am planning on using dual MPG's for X and Z so I think that I'll need a dual port BOB unless there is another way of using two MPG's. Any suggestion would be most appreciated. Bob
UC400ETH,W7 - lathe G0602
UC300ETH/M44B/C62 - mill G0619 - 4 axis (in process)
bpratl
Re: UC400ETH - best BOB?
Postby cncdrive » Fri Sep 09, 2016 2:15 pm
I think that these BOBs can't fully work with the UC400ETH, because as far as I know they both expect the second port to be an input type port where the low 8 bits (pins 2-9.) are inputs,
while the UC400ETH has a standard LPT port pinout on both ports, so the pins 2-9. are outputs on both 2 ports.
So, probably the best option is to use 2 separated BOBs which interfaces to one-one standard pinout port.
Postby bpratl » Sun Sep 11, 2016 10:37 am
cncdrive wrote:I think that these BOBs can't fully work with the UC400ETH, because as far as I know they both expect the second port to be an input type port where the low 8 bits (pins 2-9.) are inputs, while the UC400ETH has a standard LPT port pinout on both ports, so the pins 2-9. are outputs on both 2 ports.
If I use two separate BOB's, with the UC400ETH, is here any problems in configuring UCCNC in order to use separate MPG's for the X and Z axis? Are there any other interface boards required to do this or is the UC300ETH more compatible and a better choice?
bpratl
Postby cncdrive » Sun Sep 11, 2016 12:12 pm
The UCCNC has all functions configurable to any pins with ofcourse the restriction that input pins are assignable only to input type functions and output pins are assignable only to output type functions.
So, because the functions are freely configurable to pins it does not matter if you using two separate BOBs.
But the UCCNC currently supports one MPG encoder wheel only. (If the question is about that?!)
So, you can have only one wheel and the axis for the MPG are selectable via input triggers, so you can select for example the X axis and then when you move the wheel then the X axis will move and you can select the Y axis and then the Y axis will move and so on. But you can configure only one MPG wheel currently, the software does not support a second and third etc. wheels.
Postby bpratl » Sun Sep 11, 2016 12:33 pm
Thanks, I guess I will abandon my plans of using the UC400ETH on my lathe and use it on my Mill instead. I have been told that the UC300ETH can support multi MPG's so I will look into that avenue. Bob
bpratl
Postby ger21 » Sun Sep 11, 2016 12:43 pm
He's saying that the software only supports a single MPG, regardless of which hardware motion controller you are using.
Postby cncdrive » Sun Sep 11, 2016 6:22 pm
ger21 wrote:He's saying that the software only supports a single MPG, regardless of which hardware motion controller you are using.
Yes, exactly that is what I wanted to say.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 25 guests
