UCR201 USB wireless pendant
Re: UCR201 USB wireless pendant
Postby ger21 » Sun Mar 10, 2019 3:34 pm
1. I did a fresh install of the current UCCNC on an old laptop running Windows 10. UCCNC does not recognize the registration file copied into the \UCCNC folder? Im only able to run it in Demo mode. (I´m using the same LAN cable, and have rebooted several times)
Try deleting and re-copying the file.
So.... First install a clean install of current uccnc in a new folder (not overwriting anything in the existing folder.... Enable the plugin, and set up the ports and pins for motion (xyzabc axis ,estop and probe input... Run uccnc on the machine .... Does the probing work fine via the new probing screenshot in uccnc....
Ok, now install an older version of uccnc from the recommended range of the 2017 screenshot website, in another folder, enable and test the plugin (setup the axis and estop and probe ).... Now add a clean install of the 2017 screenset.... Now try again.... Does the probing work or not?
There's only one current release that supports the UCR201, version 1.2049.
There's no reason to try any other versions, as they would be test versions.
Again, CNC Drive has had two different people test with the same setup, and can not duplicate the issue.
Postby dezsoe » Sun Mar 10, 2019 3:54 pm
Hello Guys,
Before you all kill each other...
1. The issue exists. I know other people (not fom any forum) who have the same problem.
2. I cannot reproduce the issue, but saw on a video and read what it does. The symptoms are the same by everybody. I have received profiles that have the issue.
3. Gerry gave me his screenset for checking. The screenset is well written, it works fine. The issue is NOT Gerry's fault!
4. On this forum and in mail I received the same issues with the XHC-HB04 pendant. Its plugin is very similar to the UCR plugin.
Conclusion. There must be something that I don't see, but I know that it exists. I try to do my best to find it and I'll be back if I have any news. The problem is not forgotten.
Postby Robertspark » Sun Mar 10, 2019 5:00 pm
No body going to kill each other, no worry there, it's a forum for discussion not trolling.
Ok as you mentioned the xhc hbo4 which I do have is there anything I can do to help?
Happy to buy a copy of 2017 screener to help the testing cause
I have a uc300eth and uc400eth that could be rigged up for testing if it helps
Postby Robertspark » Sun Mar 10, 2019 5:03 pm
PillyWilly wrote:Okay
Did you setup the same static IP address and subnet mask as per the UC300 hardware manual?
Postby dezsoe » Sun Mar 10, 2019 5:36 pm
Thank you, Rob, at the moment: no. The only thing you could do is starting to probe with the 2017 screenset, but this is what many users do, 99% without any issues. So, it's 99% that you won't have any problems... This is the worst case in development: the unknown and rare error. :)
Postby PillyWilly » Sun Mar 10, 2019 5:41 pm
No, I might have overlooked a small detail there Rob, thank you for the reminder.
PillyWilly
Postby ger21 » Sun Mar 10, 2019 5:49 pm
Robertspark wrote:Happy to buy a copy of 2017 screener to help the testing cause
PM me your email and I'll send you a copy.
Postby PillyWilly » Sun Mar 10, 2019 7:47 pm
You will not believe this.
A fresh installation from UCCNC, on a fresh Windows installation on a laptop. Running the default screenset.
Enabeling the UCR201 plugin, and the probing fails in the exact same Way as on the PC frist used.
Am I doing something totalt wrong, or Can it be related to my pendant or the receiver ?..
Let me know what you Think, and what you want me to do.
Regards
Jan
PillyWilly
Postby ger21 » Sun Mar 10, 2019 7:58 pm
Read Dezsoe post a few posts up.
He knows the problem exists, but hasn't been able to track it down.
Postby PillyWilly » Sun Mar 10, 2019 8:18 pm
ger21 wrote:Read Dezsoe post a few posts up.
I have read all commented Gerry, have you read what I just wrote? Same symptoms on another PC.
I cannot see how this Can be software related.
I will order a cabelled pendant for testing.
Regards
Jan
PillyWilly
Users browsing this forum: Google [Bot] and 7 guests
