shad wrote:This is the short video.
https://www.dropbox.com/s/6ym4uw1vkqfbwpl/TestPauseBeforeMotion_edit.wmv?dl=0
In this cutting pierce delay set to 0.3 second, but the delay occurs after the pierce. It is clearly seen that the controller has already passed in the cutting mode, but the motion has not yet begun.
First cut is correct because in my opinion there is a delay between M3 and THCarconsignalon_emulation (time for initial Height sensing procedure).
On the next cuts was Skip IHS function and torch moved on the cut height immediately after M3.
I've checked the video, but the g-code view is too small and video quality is too low, so I can't see what's in the g-code lines.
Could you please post a small part of this code? It would be enough to post a few lines only where the pause happens and also please let me know the number of line where the pause happens.
