Maybe I threw in the towel to quickly with converter I've been working on...
Loading a R12/13/14 and problem dxf files in Qcad and Autocad and resaving will fix 99% of the problems and UCCAM will open, but splines will still be ignored.
Dan911 wrote:Try offsetting a ellipse in a CAD program, you will end up with a ellipse UCCAM will read and the offset spline it won't.
ger21 wrote:Dan911 wrote:Try offsetting a ellipse in a CAD program, you will end up with a ellipse UCCAM will read and the offset spline it won't.
In AutoCAD, set PELLIPSE to 1 and it will draw ellipses made up of polyline arcs. Not exact ellipses, but usually close enough. And can offset and still get polylines.
Dan911 wrote:Is there away to retrieve the path file for UCCAM like the Gcode path file?
cncdrive wrote:For example the attached file loads.
There was a software which we have used to just load the dxf and save it and it always saved with the proper formats for the UCCNC no matter if the original file was created with Autocad different versions,
but I just can't remember the name of that CAD software now, it was a long time ago and I forgot it's name.
Users browsing this forum: No registered users and 26 guests
