If I buy from Ebay, it's in USD, so no currency conversion. And with PayPal Credit, I have 6 months to pay, so only $30/month.
I might order one this week.
The manual is a bit weak, but it's just a bob, after all.
ger21 wrote:The biggest issue here is the lack of quality breakout boards.
There are no high quality 24V I/O breakout boards available.
Robertspark wrote:http://www.cnc4youstore.com/cnc-breakout-boards/interface-boards/
Not cheap though.... I can vouch for them on quality.
Given the number of ports and pins on a uc300 I'd suggest a stacked modular board arrangement though... With stuff like a common enable and fault connection for each drive (leadshine am882... Plus others), that way modular replacement under failure plus compact etc.
How about a breakout board similar to the ISOBOB that connects to the UC300ETH motherboard.
Or several single port boards, so that you have a system similar to CS Labs.
Maybe a 5V output board for motors. A 24V input board for home, limits and control buttons. And a 24V output board to drive relays.
As Terry said, if you could supply a complete setup, you'd be way ahead of the competition.
A_Camera wrote:Had a quick look... No, not cheap and I don't like that they are using sockets for those three chips.
shad wrote:A_Camera wrote:Had a quick look... No, not cheap and I don't like that they are using sockets for those three chips.
Just from my experience.. This three chips are the differential line drivers 26LS31 from Texas Instrument. It's works perfect and has hi immunity to the RF noise (this is very important for example for plasma cutting).
Sometimes, users can make the wrong connection and chip will be damaged. I think therefore they installed chips in sockets for quick replacement.
I am use this chips too in the pulse/direction interface of the Neuron controllers in the SO16 package (no replaceable) but have special hi speed protection from wrong connection, over current and HI voltage spikes on the lines wires and it solves all problems.
