Removing Jog panel
Re: Removing Jog panel
Postby TadasM » Mon Nov 14, 2016 7:57 pm
Thank You Gents for your help. I will test the new code tomorrow morning :)
Another question regarding jog panel. Is it possible to make panel positioned from bottom of the screen, not from top (current jog panel dimensions are 300x400) ?
Question reg. jog panel
p.s. I finally got working jog panel buttons. It is bit different from Homing buttons for eg as they maintain the current state (not only when pressed) :)
0.001 step distance buttons state UP
0.001 step distance buttons state DOWN
TadasM
Postby TadasM » Mon Nov 14, 2016 8:58 pm
Robertspark wrote:Think you need an exclamation mark before the buttonstate within the if statement
If (!buttonstate){ // ie if NOT true, then make it true,
else // if true, then make if false.
Robertspark, Gerry,
thank you, it works now :)
bool buttonstate = AS3.Getbuttonstate(20001);
if (!buttonstate)
   AS3.Switchbutton(true,20001);
   exec.Setoutpin(2, 5);
else
    AS3.Switchbutton(false,20001);
    exec.Clroutpin(2, 5);
TadasM
Postby Robertspark » Mon Nov 14, 2016 9:04 pm
TadasM wrote:Another question regarding jog panel. Is it possible to make panel positioned from bottom of the screen, not from top (current jog panel dimensions are 300x400) ?
I don't think it is possible as there are only 2 parameters associated with the jog panel (X & Y), hence no offset from 0,0 (top left hand corner co-ordinate position).
Postby ger21 » Mon Nov 14, 2016 11:14 pm
I had an idea, but tried it and it didn't work.
So no, it doesn't appear that you can.
Return to Custom Screensets
