After spending 185€ to buy the cncdrive pendant UCR201, i finally narrow the problem : After one G31 ok, no more G31 possible !
I must say that earlier that day, i made a succefull probing session. Weird.
But now...I get always the message that the probe sensor is already etc..
Hardware condition : The PC is new and dedicated, uccnc is the only software installed and running,Intel core2 6300, 4GoRam
os : win 7 up to date, NO PLUGIN but the UCR201 driver.
Soft : 1.2049
Firmware : 1.0230
Hard: 1.0
API: 2.1320
I use a UC300ETH_5LPT, serial CD112E
I set up a big led on the "run" page, duplicating the "probe" led in the diagnostic page.
The sensor is ok, and when i touch it, the big probe led turn green, and get back to grey as soon as i release the sensor.
NO FILE LOADED.
The sequence to reproduce : *** I Use the "run" screen to do all the job ***
1) Start uccnc with only the ucr201 driver enabled
2) Home all axis
3) move the head just above the sensor
4) Check, re-check, re-re-check the sensor is released.
5) G31 Z-200 F100 : works
6) set X to zero
7) G0 Z2
5) Check, re-check, re-re-check the sensor is released.
6) Again, just in case....
7) G31 Z-200 F30 : Popup the sensor was already active
6) Loop to 5)
6) I Want to die
I will send that message thrue CNBCDRIVE Support, but maybe somebody here will help ?
Sebastien
