cncdrive wrote:I think there is not really a thing like "general" ATC, because there are many different types and many of them require different control signals (Just check out Derek's ATC he posted on the forum, it is so complex), but ofcourse I understand that you looking for an example.
Please take a look into the M6 macro which installs with the UCCNC, it contains code for a simple linear ATC. That code could be used as a starting point.
Yes, we also thought about adding a string text option for buttons, I also think that it would be handy, but could not add it yet. There were always so many other important things to develop and to do.
...it needs the next test release, because in the current test release (1.2106) you can access the extended tool table only if it is saved into the profile.
