Rotary axis rollover
Postby Derek » Sat Nov 12, 2016 4:56 pm
Are there plans on implementing 360 degree rollover on the A axis?
Derek
Re: Rotary axis rollover
Postby Robertspark » Sat Nov 12, 2016 9:33 pm
I didn't think uccnc supported rotary axis, thought they were all linear and required a bit of fudging regarding angular feedrate by changing the steps per unit relative to diameter (or that's what I've been doing)
... G93 may be useful on the to-do list if looking at rotary?
Postby andrew.g » Sun Oct 21, 2018 6:16 pm
I am also wondering if there is a plan to implement axis rollover option at 360 degrees as in Mach3.
andrew.g
Postby cncdrive » Wed Oct 24, 2018 8:23 am
Yes, it is on our list.
Postby ger21 » Wed Oct 24, 2018 10:33 am
Hopefully G93 as well?? :D
Postby cncdrive » Wed Oct 24, 2018 5:21 pm
Hi Gerry,
Yes, we have that too. :)
Postby Greolt » Wed Oct 24, 2018 10:31 pm
Vmax549 wrote:How about with the Axis rollover you use a switch like with Machine and Work coords. Click on teh switch and it displays the REAL rotary coords and press it again and it displays the roll over coords.
Not seen that before but it sounds like a good idea.
Or perhaps even better a DRO for real as well as rollover. So that I could have both on my custom screenset.
Greolt
Postby Greolt » Thu Oct 25, 2018 6:33 am
OK thanks for that Terry
That will be useful when we get the rollover function included.
But as has been said, it really only becomes applicable after we get G93
Greolt
Postby ger21 » Thu Oct 25, 2018 12:18 pm
He won't be using the rotary until he can use G93. :D
Postby cncdrive » Thu Oct 25, 2018 3:18 pm
BTW, what is the purpose of axis rollover. We have it on our list, because some people asked about it, but the only thing I can think of when this can be useful is a rotary knife when it is better if the axis rotates to the shorter direction. By shorter direction I mean that if the axis rolls over then only 0...360° is available and so when you code an angle then the direction of movement is not clear, the only way to decide is by shorter or longer path. And for rotary knife the shorter path is the better because then the movement happens faster.
But other than the rotary knife application I have no clue for what else applications could this feature be useful?!
