Recently while cutting a bunch of 3/8" plates each containing a number of 7/8" holes, I encountered a strange, but consistent error phenomenon. The parts were arranged on a 4x8' sheet in an array built using Sheetcam. The first column of rectangular plates started cutting from the lower left corner of the 4x8' sheet then proceeded up one side of the sheet along the Y axis. The first of four holes cut properly in each part, but the second and third hole would only pierce, do the lead-in then a very short arc before flaming out and moving over to the forth hole which cut correctly. The square plate cut correctly as well.
It happened on each plate along the left side of the sheet. When the first column was complete, the torch moved over and began cutting the next column moving back to zero along the Y axis. Every plate was cut correctly with no holes skipped. The same was true of the third column moving back up along the Y axis. Because of the number of parts required for the job, it was necessary to place four more parts along the far right edge of the sheet, but turned 90deg to the right in order to fit. I simply made another duplicate of the first original part (lower left corner) then turned it and placed all four from lower far right on up, along the Y axis. These four plates suffered the same fate as the first eight. Again, the first hole cut correctly then the second and third holes were skipped, but the forth cut correctly.
At the time I didn't spend much time trying to figure it out as I have access to an "Iron Worker" so was able to simply place the incomplete plates on the press and punch out the remaining holes. It was only when moving to another phase of the job where I discovered the "interesting phenomenon." I was cutting some 12x12x3/4" plates with a single 1-1/2" hole in its center that I saw the same problem. As there is no hole punch on the Iron Worker big enough to punch that size of hole, I decided to do a dry run with the torch turned off. I couldn't believe my eyes when I saw the same behavior! This was a serious problem for me as the customer had given me a tight deadline to get 16 of these plates cut for a job he was doing. I decided to try a different software version. (I was running 1.2104 at the time.)
I downloaded and installed 1.2106 thinking that it would make the problem go away. Nope! Still there. Now what. I don't know exactly why, but after closely examining the code and finding absolutely nothing in it that would explain the problem, I decided to try a little experiment. Sheetcam seems to favor all X or all Y motion as defaults for setting up lead-ins for circles. This time was no different so "Hmmm", I thought, "let's try something different." I changed the circle lead-in so that it was running on a diagonal instead of orthogonally then regenerated the code. I loaded it up then did another dry run. Yee hah! It worked! No more holes skipped. I was able to complete the job of cutting 16, 1 foot square by 3/4 inch plates and my customer was happy.
Now can someone please explain why? If anyone is interested I will upload the offending .tap files.
BTW, this is a problem I had experienced numerous times when still running Mach3. It was probably THE main reason I decided to purchase a US300ETH and UCCNC. Very disappointing/discouraging to see the same problem continue to rear its ugly head.
My current setup:
- 4x8' table
- UC300ETH
- Gecko G540 drive module
- UCCNC software v1.2106
- P.O.S. pc running Win XP
- Hypertherm powermax85
Thx. John
