G41-G42
G41-G42
Postby claudio » Wed Sep 26, 2018 7:08 pm
Hi!,
I red the topics about G41 e G42 code.
But I don't understand very well if I can use them and how. They are not in gcode list.
In some program there is this command: G41 D1 what means D1?
I saw some examples with this gcode and I put it in the software and run it in demo mode; the program runs but the line
with G41 (for example) becomes red; what does this mean? Is it an error?
Seeing the toolpath I don't understand the difference between G40 e G41.
I am sorry for my poor english,
thank you all for your help
Claudio
claudio
Re: G41-G42
Postby Robertspark » Wed Sep 26, 2018 9:00 pm
What version of uccnc are you using?
I don't think it matters but are you using a uc100, uc300usb, uc300eth, uc400eth?
Do you understand what g40, g41 and g42 are?
http://cnc-programming-tips.blogspot.co ... n.html?m=1
G40 is no cutter compensation
G41 will offset the cutter to the left
G42 will offset the cutter to the right of the cut line.
I don't think it is visible in the toolpath display it just offsets the cutter (or not)
UCCNC has two versions, a stable release for those who want it for production with minimal glitches and issues (is they have been picked up and rectified)
Available here http://cncdrive.com/UCCNC.html
And the development release which is or can be sometimes unstable ... It is released with any new features that cncdrive decide to incorporate with a view that they are tested and any bugs are raised
It is available in this thread
viewtopic.php?f=2&t=240
Current stable release is 1.2048 (and after looking in the manual on the cncdrive website g40,41 and 42 are not incorporated yet)
Current development release is 1.2106 and does incorporate g40, g41 and g42, and has its own manual which is installed within the documentation folder wherever you install it on your hard drive (normally c:\uccnc\documentation\
Re: G41-G42
Postby Robertspark » Thu Sep 27, 2018 9:58 am
extract of the uccnc users manual for development version 1.2106
UCCNC_usersmanual - G40 G41 G42 extract.pdf
(1.08 MiB) Downloaded 742 times
Re: G41-G42
Postby claudio » Thu Sep 27, 2018 5:03 pm
Thank you for your answere,
your informations are very useful for me; I now the radius compensation because I programming with
Heidenhain, Selca, Fanuc CNC language but I did not understand if I could use them with UCCNC.
Can I download the version 1.2106? and if is it possible, were?
Thanks again
Claudio
claudio
Re: G41-G42
Postby ger21 » Thu Sep 27, 2018 6:29 pm
The last post in this thread.
Re: G41-G42
Postby claudio » Fri Sep 28, 2018 4:07 pm
Thank you,
I will try it
claudio
Users browsing this forum: Bing [Bot] and 12 guests
