What version of uccnc are you using?
I don't think it matters but are you using a uc100, uc300usb, uc300eth, uc400eth?
Do you understand what g40, g41 and g42 are?
http://cnc-programming-tips.blogspot.co ... n.html?m=1G40 is no cutter compensation
G41 will offset the cutter to the left
G42 will offset the cutter to the right of the cut line.
I don't think it is visible in the toolpath display it just offsets the cutter (or not)
UCCNC has two versions, a stable release for those who want it for production with minimal glitches and issues (is they have been picked up and rectified)
Available here
http://cncdrive.com/UCCNC.htmlAnd the development release which is or can be sometimes unstable ... It is released with any new features that cncdrive decide to incorporate with a view that they are tested and any bugs are raised
It is available in this thread
viewtopic.php?f=2&t=240Current stable release is 1.2048 (and after looking in the manual on the cncdrive website g40,41 and 42 are not incorporated yet)
Current development release is 1.2106 and does incorporate g40, g41 and g42, and has its own manual which is installed within the documentation folder wherever you install it on your hard drive (normally c:\uccnc\documentation\
