Testing the virtual mouse. The motion responce is good BUT when you move to a DRO and then enter a number and then hit enter it does NOT stick it clears out the DRO ready for you to enter a number again.
I have similar problem when use pop up calculator for manual data input to the DRO. After then pop-up window closed and new value was validated from plugin, on the DRO still "|" character. May be you can add in the DRO validate function code for unfocus DRO?
cncdrive wrote:- UC300ETH_hi and UC300ETH_low motherboards configurations had an issue and the software did not startup in these modes, fixed.
