M130 UccncMediaViewer
Re: M130 UccncMediaViewer
Postby Robertspark » Fri Sep 14, 2018 8:31 am
I think {not sure, not tried it} it may be possible to change:
if(result == "jpg")
to
if(result == "jpg" || result == "bmp" || result == "gif" || result == "png" || result == "tiff" || result == "wmf" )
given the system drawing namespace can open / display a number of image formats and is not just limited to jpeg
https://docs.microsoft.com/en-us/dotnet ... work-4.7.2
I personally like png as the file size is so much smaller and therefore can load quicker from my experience.
each to their own.
Good work terry,
Postby Dan911 » Fri Sep 14, 2018 9:00 am
Hey Terry this was done already, you replied in the thread. I also showed an example how to use the .html file Vectric software outputs.
viewtopic.php?f=13&t=1183&p=8928#p8928
Postby Dan911 » Sat Sep 15, 2018 1:36 am
Took a better look tonight and see you created a universal MediaVeiwer macro...Nice work. I only tested on the OP request for Fusion where the M130.png is automatically generated in Gcode.
To automatically generate with Vectric software adding this to the header of your post processor "[N] M130 ([TOOLPATH_NAME].html)" works and what I did, you just need to name the job summary the same as the generated toolpath.
Return to UCCNC TOOL BOX
