Huanyang VFD plugin
Huanyang VFD plugin
Postby Gene8522 » Wed Aug 15, 2018 2:04 am
Reinstalled 2017 Screenset profile. I checked 2017 Screenset to see if it had imported the settings from UCCNC some of the setting are there. Like the "Steps per unit", "Velocity" etc. but the Ports & pins needed to be put in. Which I was able to do.
I tried to manually input the settings but there are things that will not set i.e.; 'Enable X,Y,X' all of the 'Active Low' and 'PWM spindle' check boxes. Is there something I over looked?
I can input the ports & pins numbers but that's about all.
The UC300ETH is working because I see changes in the diagnostics when I touch the moveable touch off plate or trip the E-Stop.
Gene8522
Re: Huanyang VFD plugin
Postby ger21 » Wed Aug 15, 2018 10:37 am
I explained this in the other thread.
viewtopic.php?f=2&t=1435
