Older UCCNC copy
Re: Older UCCNC copy
Postby Robertspark » Tue Aug 07, 2018 9:30 pm
https://cncdrive.com/UCCNC.html
Two older versions are on the main page
I go as far back as 1.2026 (maybe a little older)
Postby ger21 » Wed Aug 08, 2018 1:33 am
I have 1.0034, 1.012, 1.1022, 1.1026, 1.1027.
Which one do you want? I can upload them and send you a link.
Postby ger21 » Wed Aug 08, 2018 2:00 pm
I'll get you a link this evening.
Postby cncdrive » Wed Aug 08, 2018 2:16 pm
The 1.0034 is available for download on our website in the archives. It is the latest 1.0xxx version.
http://cncdrive.com/UCCNC.html
Just fully roll down the page and you will find the link to the download.
Postby dezsoe » Wed Aug 08, 2018 3:40 pm
Umm... It's interesting. I installed the 1.0034 from the link and it sais, it's 1.0034, but only knows the UC100. I have an old download from 2014 October, version 1.0034 and it already knows the UC300_5LPT. Both shows in help/about 1.0034, but they are completely different. :o
Postby cncdrive » Thu Aug 09, 2018 12:39 pm
Make sure to delete the UCCNC.config file if you installed that early version over the 1.21xx version, because those new versions run on .net 4.0 and so the config file is required to allow to load 3rd party plugins,
but the old software installer does not delete the config file and also because it runs on .net 2.0 a config file is not installed.
And so if the new version's config file remains there then the app will crash because it tells Windows that the app requires .net 4.0 while it is .net 2.0 code.
Postby cncdrive » Fri Aug 10, 2018 1:23 am
Then maybe the Flashplayer is missing from the computer or has the bug which was introduced at the time when we ported the whole UCCNC to OpenGL from Flash.
I did not follow up on if Adobe ever fixed that Flashplayer bug or not, because we no more needed it, so it is just a guess.
Users browsing this forum: Bing [Bot] and 16 guests
