v.1.2105 - List object issue.
Postby kig23 » Tue Jul 17, 2018 3:17 pm
if you click inside the list object on some of the messages the result is that the clicked line becomes black with white text, but after that when you press the clear button the black line remains. Is that the way the list object works or i'm missing something. Unfortunately I can not attach photos because I get this message (Sorry, the board attachment quota has been reached).
Thanks.
kig23
Re: v.1.2105 - List object issue.
Postby kig23 » Sat Aug 04, 2018 9:08 am
i hope Balazs will anser this post. Like i wrote, if one of list oblect messages is selected, the selected line becomes black (picture1), but after that when you press the Clear button the black line remains (picture2). There is another thing. When you have messages in the list object and scroll down (picture3) and then click the Clear button, that will clear the messages but doesn't initialize the list object on the first line (picture4) and IMHO you can lost messages if you don't pay attention to scroll up the control manually. Thank you.
kig23
Postby cncdrive » Sun Aug 05, 2018 2:37 am
You can't loose messages, better to say that you can miss to see messages. I mean messages will not be lost just the Clear button does not scroll up and does not remove the selection mark.
I will fix this for the next release.
Postby kig23 » Sun Aug 05, 2018 7:44 am
Yes, you're right. I meant that you can miss to see messages. Thanks Balazs and if it's possible to make the control transparent should be great.
kig23
Postby cncdrive » Sun Aug 05, 2018 1:36 pm
OK, I'll add a backgroundcolor and backgroundtransparency parameter.
Postby kig23 » Sun Aug 05, 2018 4:31 pm
Thanks indeed. Great.
kig23
