Rigid tapping- first real one!
Postby Battwell » Fri Aug 03, 2018 1:32 pm
Re: Rigid tapping- first real one!
Postby cncdrive » Fri Aug 03, 2018 1:59 pm
Nice. tap tap tap. :)
Postby Battwell » Fri Aug 03, 2018 6:50 pm
il try it to whatever i can- with new tooling and coolant- waiting for both to arrive!
(not usually a metal man- so havnt worked out where speeds should be yet.)
Postby Battwell » Fri Aug 03, 2018 9:15 pm
Just watched a haas video re rigid tapping- and how to make it faster.
Very nice easy to add feature of faster retract speed
Feature request :-)
https://youtu.be/GrPdQDpGQMI
Postby Robertspark » Fri Aug 03, 2018 10:55 pm
Interesting, think it will be a quick feature no one else in the hobby / DIY CNC market has
Postby spumco » Sat Aug 04, 2018 4:34 am
Nice.
Form taps are your friend for aluminum and softer metals.
spumco
Postby Robertspark » Sat Aug 04, 2018 5:00 am
Do form taps not require a lot more torque to use
Postby Derek » Sat Aug 04, 2018 9:49 am
Not that I notice. You use a larger hole size. The taps for me last a long time and the threads are beautiful and stronger in aluminum.
Derek
Postby Battwell » Sat Aug 04, 2018 11:27 am
These weren't out when I went to school!
And my main work is wood- so I hadn't come across them.
I've just ordered 2 to try.
It will be interesting to see if my 1kw spindle is man enough for m6 and m8 in aluminium
Postby Battwell » Sat Aug 04, 2018 11:31 am
I tried mine a bit faster last night.
Only 2nd ever try at machine tapping - but I was happy
And my punter for the machine can't wait to have it :-)
https://youtu.be/b2q2Ou12vs8
