I am the new user of UC300ETH motion controller and UCCNC software version 1.2047.
The computer works under Win XP sp3.
Everything works properly except for a spindle connection.
For connection I use RS485 and Huanyang plugin ver. 1.0012. UCCNC reports an error (UCCNC has encountered a problem and needs to close) when VFD is on. If I start UCCNC with VFD off, it is normally loaded and running. If I turn on the VFD after a few seconds, the error reappears. Although a reported error, the connection between the VFD and UCCNC works, (I can turn the spindle on and off and change the speed). The Sact field does not show a change in speed. The field with the reported error remains on the screen.
I set the parameters for VFD and plugin according to the instructions from the plugin (attached pictures).
For Mach3 I use royaumedeole mach3-plugin-for-huanyang-vfd 1.7.1 and everything works properly.
Can you help me, please?
