Screenset 2019 Vertical (Portrait)
Postby Algone » Wed Jul 17, 2024 9:59 am
Hello everyone, I recently purchased a 22" touch screen, having not found a vertical screenset that I liked, I decided to transform the 2019 screenset into portrait mode. I have spent a lot of time, it wasn't easy but I got there and I said to myself why not share it with the community. I specify that it is optimized for the UC300 ETH 5PLT. I started to convert it for other cards but not finished, you will be able to adapt it without too much difficulty, the bulk of the work having already been done, I used the superb tool UCCNC Screen Editor by Eldar Gerfanov https://snapwebapps.com/uccnceditor/ which in the end is less complicated than it doesn't seem to be there.
Not having finished my machine I was not able to test it but normally I was careful to respect everything.
There may be some errors not corrected despite my vigilance, if you see any let me know, I will correct them.
To install it, unzip the folder and copy it to C:\UCCNC\Flashscreen\BMP\ once done, in this folder there will be the file "2019 - Verti.ssf" which you will need to cut and paste into C: \UCCNC\Screens and of course load it into UCCNC.
https://drive.google.com/uc?id=1u2pMypAR4uBGH-Sj1zt5txWxleT5SkC1&export=download
Alex
Algone
Re: Screenset 2019 Vertical (Portrait)
Postby valhallaCNC » Wed Jul 17, 2024 7:35 pm
Do you have any screenshots..thanks
valhallaCNC
Postby Algone » Wed Jul 17, 2024 10:08 pm
Effectively I forgot a capture ;)
Algone
Postby cncdrive » Thu Jul 18, 2024 11:13 am
Nice. Thank you for sharing. :)
Postby Algone » Thu Jul 18, 2024 4:38 pm
Algone
Postby Tu4r3g21 » Wed Aug 14, 2024 3:44 pm
Thanks a lot for sharing.
I think, this is one of the features i was hoping most for the past year. To have a proper portrait mode for the machine, that allows to use the onscreen keyboard without distorting the UI unusable, ditch all other devices aside the pendant and operate the machine fully via the monitor.
Unfortunatly i would not be much of a help updating that screenset, but if you spent more effort into this project and update more of the other screens, be sure you're having a big fan here and your work would be very much appreciated!!
Thanks a lot!!
Tu4r3g21
Return to Custom Screensets
