Macros on the Ger,s 2022 Screenset for pendant?
Postby Mopar71 » Fri Feb 16, 2024 9:58 pm
Hi Ger! I have been using screenset 2017 with Mach3 until very recently. But bought UCCNC and your Screenset 2022 and I am now installing my HB-04 pendant. Previously, I used it, among other things, to run Z Auto Zero and Auto Zero initialize directly from the macro buttons on my pendant. Is there any possibility to do the same with your 2022 version?
Regards Eric
Mopar71
Re: Macros on the Ger,s 2022 Screenset for pendant?
Postby Mopar71 » Sat Feb 17, 2024 7:43 am
(Edit) It was the 2010 Screenset that I used earlier.
Mopar71
Postby ger21 » Sat Feb 17, 2024 1:35 pm
If the pendant allows you to assign button numbers, then yes. The button numbers are in the screenset manual.
If it doesn't work, I have an alternate plugin you can try that might work. Send me an email and let me know.
Postby George M » Sat Feb 17, 2024 2:14 pm
Hey Ger,
I meant to get back to you.
While using the UC201 the plugin works fine with V16, but gets errors with V15. When it gets a bit warmer here I can get the the specific errors that it shows.
Thank you
George M
DIY CNC Machine
UCCNC
UC300eth-LPT5
UCBB
George M
Postby Mopar71 » Sat Feb 17, 2024 3:00 pm
ger21 wrote:If the pendant allows you to assign button numbers, then yes. The button numbers are in the screenset manual.
I will do that. Thanks for the reply! :--)
Mopar71
Postby ger21 » Sat Feb 17, 2024 3:11 pm
OK, let me know. I played around with it in 1.2115, and didn't see any errors, but I don't have a pendant.
Return to Custom Screensets
