screenset image editing
Postby Robertspark » Fri Sep 09, 2016 6:37 am
Hello,
I see that the screenset images are *.PNG indexed, anyone got any easy suggestions for image editing to swap colours.
(war of the screensets.... I like the images, just prefer different colours [black & green])
Don't want to attempt to reinvent the wheel, hence thought I'd ask what others may be using for image software.
Thanks, Rob
Re: screenset image editing
Postby ger21 » Fri Sep 09, 2016 12:20 pm
I use Photoshop, but Gimp is a free alternative.
Postby CT63 » Fri Sep 09, 2016 1:26 pm
I use paint.net... free. Would love to use Photoshop but it's out of my price range.
CT63
Postby ger21 » Fri Sep 09, 2016 2:53 pm
With Adobe's new subscription plans, it's $10/month.
Postby Robertspark » Fri Sep 09, 2016 7:19 pm
Thanks very much ..... started editing them this evening.... wow.... think I'll just stick with the default screensets (until Gerry comes out with one [customers lining up!])
To be fair other than personal visual taste there is not anything I can see as not there.
Rob
Postby CT63 » Sat Sep 10, 2016 2:05 pm
The built in screen editor is a little challenging to use at first but easy to get the hang of. I'm all for simple screensets. The flashscreen folder has blank backgrounds that I used to build a new 3 axis "Run" screen and then a X/Y probing screen. Did the design work using Paint.net. My only comment to CNCdrive is the supplied screenset is overly cluttered.
CT63 Screenset1.jpg (76.54 KiB) Viewed 30088 times
CT63
Postby thegreatwaldo » Sun Sep 11, 2016 8:56 am
CT63 wrote:The built in screen editor is a little challenging to use at first but easy to get the hang of. I'm all for simple screensets. The flashscreen folder has blank backgrounds that I used to build a new 3 axis "Run" screen and then a X/Y probing screen. Did the design work using Paint.net. My only comment to CNCdrive is the supplied screenset is overly cluttered.
Hi CT63
That screen looks great. Would it be possible to have a copy of it ? If not no problem. I have just started working through the screen editor trying to do a screen myself your machine coord box looks good. It's a bit of a trek sifting through the background files. I'm much better with wood than software.
Cheers
Andrew
thegreatwaldo
Postby CT63 » Sun Sep 11, 2016 12:32 pm
Cheers
PM sent
CT63
Postby thegreatwaldo » Sun Sep 11, 2016 2:23 pm
Hi George
I sent you a pm with my email, please let me know if it does not reach you.
Cheers
Andrew
thegreatwaldo
Return to Custom Screensets
