True Type Font.....
True Type Font.....
Postby krsykes23 » Tue May 31, 2022 7:40 am
I'm trying to add a specific font to a DRO but when I select it from the fonts list, it says "Only True Type Fonts are supported. This is not a True Type font".
The font is definitely a TTF.
krsykes23
Re: True Type Font.....
Postby ger21 » Tue May 31, 2022 3:35 pm
What is the font?
Postby krsykes23 » Tue May 31, 2022 8:01 pm
Hi Gerry,
It's a 7-segment style font. Interestingly enough, I tried another similar font but the digits 'shifted' a lot when counting up/down. I guess the reason for this was that a number 1 was smaller in size than a number 8 for example...hence the 'shift'.
That said, it did allow me to add this font even if I wasn't happy with it. I checked the properties of this font against the one I'm trying to add and they looked identical.
Yep....I'm fussy!
SEVEN SEGMENT.TTF
(28.39 KiB) Downloaded 393 times
krsykes23
Postby ger21 » Wed Jun 01, 2022 4:15 am
Is this the font that does not work for you? It works fine for me.
Postby krsykes23 » Wed Jun 01, 2022 8:01 am
Not sure what's going on here. I just tried it again and it worked!
krsykes23
Postby dezsoe » Wed Jun 01, 2022 1:41 pm
Don't run UCCNC while you install the font. I found this font which looks much better and is monospace.
Postby krsykes23 » Thu Jun 02, 2022 7:26 am
dezsoe wrote:Don't run UCCNC while you install the font. I found this font which looks much better and is monospace.
Hi Dezsoe,
I changed the font to the DSEG Classic type and it worked much better than the seven segment version I described earlier. Then I saw your reply! Thanks for the comment on installing fonts. I did wonder whether the font error message was generated by UCCNC or Windows.
krsykes23
Postby 2046 » Mon Jun 27, 2022 10:23 pm
speaking of fonts https://fonts.google.com/
Return to Custom Screensets
