Custom Screenset ... complete new design (Dark theme)
Postby cseyler » Sun Dec 26, 2021 9:50 pm
Hello,
I would like to share my Work In progress Screenset.
My goal is having a screenset without the job panel, and optimized for a touchscreen. The touchscreen I use is a 14 inch 16:9 display.... The elements' size are ok ... but I have small fingers. I guest a 15 or even a 17 inches monitor should be better.
So, I remove all up/down boxes as far as I find them not "touchscreen friendly" at all. I probably get them back when I would find a way to cutomize their behavor (and their ugly look :D) : i think about having the down/minus on the left of the textbox, and the up/plus on the right.
Furthermore, the screenset is adapted to my CNC : a 3 axis + 1 (rotary) + a laser
Then, here are some screenshot of the actual state
The main screen
Main Screen
As I use a VFD connected through a RS485 link, I rewrite the communication plugin to allow to get some status LED when the COM port is opened, and when the VFD communication is OK. I also add the ability to configure the plugin parameters through fields and buttons. So, in the next step, I will add these setting in the "settings/spindle" panel
Somes settings screens
Settings - General
Settings - IOSetup
Settings - Display
I've also changed the way to display the help panels:
The texts are got from text files : so it is easy to all new help / remainder for example the user macros, or any other help messages
Help 1
Help 2
The next big work is the probe panel ... stay tuned
cseyler
Re: Custom Screenset ... complete new design (Dark theme)
Postby cncdrive » Sat Jan 01, 2022 8:14 pm
This looks nice. Will you share it later on or ... ?
Postby cseyler » Sun Jan 02, 2022 9:18 pm
at this stage, i don't know yet. As I adapted the sceenset to my cnc configuration, there are a lot of options I get rid off (THC, spindle settings (as i use a RS485 VFD)...)
Furthermore, the screenset also requires several plugin to work ... it would probably be too much constraints for a normal user
cseyler
Postby Roby » Wed Jan 05, 2022 10:24 pm
This looks awesome awesome.
CNCdrive should commission you to build this out and include it with their software :-)
I've always wanted to see Minimum Z for the job on the Main screen. I'm surprised more screensets don't show this. Is that just me?
Roby
Postby ger21 » Wed Jan 05, 2022 11:35 pm
Looks really, really good. How do you make the custom sliders and scrollbars?
Postby chris49 » Sun Jun 12, 2022 4:31 pm
Awesome !!! GREAT JOB
chris49
Return to Custom Screensets
