Latest Atc conversion
Postby Battwell » Mon Nov 02, 2020 2:19 pm
Old axyz machine brought back to life
Uc300eth and uccb
New stepper drives
Single phase conversion
Fully sorted Atc for tools up to 96 sorted into tool pockets
[youtube] https://www.youtube.com/watch?v=LKthJNp ... ture=share[/youtube]
Re: Latest Atc conversion
Postby Battwell » Sun Nov 08, 2020 2:41 pm
Just added analog pressure transducer to check incoming air supply pressure for Atc safety
https://youtu.be/rlMj7BVeQsQ
Postby needleworks » Tue Nov 10, 2020 3:40 pm
Excellent work buddy, I just wish I had your skills/knowledge :geek:
needleworks
Postby CL_MotoTech » Wed Nov 11, 2020 1:53 pm
I was just looking at doing this after having seen a Haas that recently crashed the ATC with low pressure. Of course it has a sensor to stop this, but apparently something else failed.
That said, I don't want to crash my ATC, and I currently don't have a pressure sensor. How hard is this to setup?
CL_MotoTech
Postby Battwell » Thu Nov 12, 2020 11:40 am
sensor is simple fit- just 3 wires. 5v, gnd and analog signal.
i added a text field to the screen to write to and display.
the math was pretty hard for me to get my head around as it only outputs 0.5v to 4.5v
but i worked it out and wrote a macroloop to monitor it and update the text field.
i can then read that text field before any m6 operation starts to check its value . i have it checking value is above 95 psi before allowing atc to run
i can post the macroloop and check codes for you to use. the transducer is only about £13 in the uk.
https://youtu.be/5-QRSI5PBL0
Postby Battwell » Thu Nov 12, 2020 11:42 am
Postby CL_MotoTech » Fri Nov 13, 2020 2:16 pm
Ahhh, I've seen your machine on the Facebook group!
There is verbage in my M6 macro for a pressure sensor, but more than anything I was concerned with how I would calibrate that sensor for UCCNC. I have calibrated various .5v to 4.5v sensors for various data loggers, but UCCNC isn't exactly setup in that manner.
CL_MotoTech
Postby CL_MotoTech » Fri Nov 13, 2020 2:21 pm
That text field with PSI readout is epic!
I run a pretty small compressor, it's low volume, but also low noise. I designed my PDB and ATC around a 90psi minimum. The only time I have had an issue with air since building the machine was when I left the compressor unplugged, or the mill unplugged from the air supply. This results in a fail tool change as the ATC carriage has a hall effect sensor that signals that it at least moved off it's stop. That said, I hate for the carriage to make it's way under the spindle and the PDB fail to release the tool. It would probably do some pretty big damage to the carousel. I also use this same compressor for shop air, so I have to be really careful.
CL_MotoTech
Postby Battwell » Sat Nov 14, 2020 10:48 am
Postby Battwell » Sat Nov 14, 2020 10:53 am
The -2688 used is the actual reading of the analogue variable at zero psi which gives correct calibration offset
