UCCNC STEPCRAFT Label Making
Postby StoneyCNC » Fri Jan 16, 2015 9:00 pm
Toolpaths generated in VcarvePro and the UCCNC software used to control a STEPCRAFT S420 to machine labels out of Gravoply.
StoneyCNC
Re: UCCNC STEPCRAFT Label Making
Postby LordVishnu » Mon Nov 07, 2022 11:01 am
This is a quick demo of the setup and operation. The labels are for the face plates on a Z axis control board I built for my router. I made 3 of the boards, so I needed 3 sets of labels. I made 4 sets of labels, actually. I lost one of the boards and had to make another.
The setup is pretty simple. I run the UCCNC software on a Windows 10 laptop and use an old ethernet cable to connect the laptop to the controller on the router. I have the router connected to a 120 VAC circuit via a power strip. I have a USB cable running from the controller on the router to the laptop.
I have a 2.2 kW spindle motor on the router, a 2.2 kW inverter, and a set of VFDs. The spindle motor and inverter are from STEPCRAFT, and the VFDs are from a Chinese supplier.
I use a De Walt router with a 1/4 inch diameter spiral up-cut end mill when machining the labels.GB Whatsapp
LordVishnu
Postby thegreatwaldo » Mon Dec 05, 2022 10:59 am
I'm just seeing an empty white space! what exactly have you posted?
Cheers.
Andrew
thegreatwaldo
Postby ger21 » Mon Dec 05, 2022 12:18 pm
For me it says the videos are private.
Postby itsmiro » Mon Dec 19, 2022 9:23 am
The above video is private and it is also not available in its source. That's why its blank..
itsmiro
