Just for fun.
Re: Just for fun.
Postby andre99 » Sun Dec 27, 2020 1:16 pm
Thanks yesterday I made a direct fresh air hose adapter so that my lens stays cleaner. The hose goes to the side of my cabinet and I also placed a small 12 volt computer fan on the outside of the cabinet there, to get enough fresh air into the hose. I am now testing with 0.5 y axe and I load a picture directly in uccnc plugin no filters at all. I hope that the resolution becomes better.
Thank you for helping me like this
andre99
Re: Just for fun.
Postby Robertspark » Sun Dec 27, 2020 1:20 pm
nice :)
Re: Just for fun.
Postby andre99 » Sun Dec 27, 2020 1:59 pm
Tweakie.CNC wrote:Hi Andre99,
If it’s any help, I never get involved with d.p.i – I just download my photo or image (in the highest resolution I can) then (consistent with the UCCNC allowance) load it into the UCCNC Laser Engraving Plugin, select Grayscale (Laser mode 1), select the desired size and Y scan distance. Do a partial trial run to set my correct laser power level then go for it.
You don’t really need to see more of my work but I have attached my cardboard lasered cat image just for reference.
What is the wavelength of the laser you are using ?
Tweakie.
What are your settings I try to do my best but I stay with little ditty picture.
I putt y on 0.04 and speed 1500.
What settings did you use ???
andre99
Re: Just for fun.
Postby Tweakie.CNC » Sun Dec 27, 2020 3:29 pm
My Y was 0.15mm and my speed 4,500mm/min. (my laser is 40Watt).
Tweakie.
Tweakie.CNC
Re: Just for fun.
Postby andre99 » Sun Dec 27, 2020 3:41 pm
Aha oke yes you have a c02 laser yes that's why my resolution is different.
But I keep trying, I just cut a cardboard box in pieces so enough test
material.
I'm testing nog a new picture wanna look how that comes out.
andre99
Re: Just for fun.
Postby andre99 » Mon Jan 04, 2021 10:24 pm
Testing white tiles but the trick is to find the right paint for it.
andre99
Re: Just for fun.
Postby andre99 » Mon Jan 04, 2021 10:29 pm
And the same one a ceramic Tile 148x148mm
Further playing with cardboard is fun cheap material for testing.
andre99
Re: Just for fun.
Postby Tweakie.CNC » Tue Jan 05, 2021 5:56 am
Excellent work, my congrats on your progress.
Tweakie.
Tweakie.CNC
Re: Just for fun.
Postby andre99 » Thu Jan 07, 2021 10:46 pm
I'm getting closer and closer to perfection, it is hard to learn but
I will go own. My Opt laser 6 watt with Uspot lens works perfect.
Today I made this tile 10x10cm
Further I go an tweak more to get better result and higher resolution.
andre99
Re: Just for fun.
Postby Tweakie.CNC » Fri Jan 08, 2021 6:05 am
Looking good.
Tweakie.CNC
