Just for fun.
Re: Just for fun.
Postby Robertspark » Fri Jul 03, 2020 2:06 pm
Tweakie.CNC wrote:
would this work for a tile installed in a bathroom or is it likely to not fare very well because of the condensation / mould potential?
(I am still conducting the dishwasher trials :lol: ).
Does the wife know? :lol: :roll:
I have on occassion been known to dry out dessicant in the oven....... (shh!).... timing is eveything :shock:
Re: Just for fun.
Postby andre99 » Fri Dec 18, 2020 1:35 pm
Tweakie.CNC wrote:Part 2…
Trying different laser techniques using UCCNC and the Norton (Paint / Paint stripper) method.
The etching is certainly permanent and cannot be removed with stripper or solvents but it is nowhere near a dark as Rob’s previously linked example and I don’t yet know what is causing the herring-bone styrations.
Obviously it is work in progress. :lol: :lol: :lol:
Tweakie.
Hello i send you a pm message i really hope you want to learn me how you did it \
andre99
Re: Just for fun.
Postby Tweakie.CNC » Fri Dec 18, 2020 3:07 pm
Hi Andre99,
The process is really simple…
Use a cheap, glazed ceramic tile – spray with a thin coating of white paint and leave to dry (rattle can undercoat is just fine) – use the UCCNC laser plugin to laser your picture onto the tile (slow feed-rate) – remove the residual paint with thinners or paint remover and that’s it, tile completed.
Like all things it may take some practice to get it perfect but it is not difficult.
Tweakie.
Tweakie.CNC
Re: Just for fun.
Postby andre99 » Sat Dec 19, 2020 8:20 am
Hi Tweakie,
Oke but what is the best way to prepare a photo ore must I just putt the original
One straight in.
Further what settings in that plugin is the best giving results??
Do you have messenger maybe whe can talk in there together??
I really want to learn from you.
Do you have some pictures from your designs on tiles .
andre99
Re: Just for fun.
Postby Tweakie.CNC » Sat Dec 19, 2020 9:04 am
Hi Andre99,
You have to first learn how to use the UCCNC 'Laser Engravin Plugin'. I suggest you practice on waste cardboard using different Modes and settings until you are able to get reliable and satisfactory results. It is not difficult and it is essential learning.
Chose an image which has a good contrast ratio to practice with (download something from the net) and just keep practicing until you get it right. Then try a tile and see how you get on.
Tweakie.
Tweakie.CNC
Re: Just for fun.
Postby andre99 » Sat Dec 19, 2020 9:23 am
But must I prepaid the foto on https://www.imag-r.com/
And then the new Norton white tile filter??
Ore must is just a normal color photo.
Maybe you can explain how you do it in steps.
Thanks that you are willing to help me.
Do you have some pictures things you done on tiles.
Further the % laser power is that just 100% ore is there also a different settings for.
Ore just take greyscale, halftone ore Dithering??
andre99
Re: Just for fun.
Postby Tweakie.CNC » Sat Dec 19, 2020 10:06 am
I have attached an image for you to practice with.
Just experiment as I mentioned in my earlier post.
Tweakie.
Tweakie.CNC
Re: Just for fun.
Postby Tweakie.CNC » Sat Dec 19, 2020 11:26 am
Another image but this time monochrome, which may be easier for you to practice with.
Tweakie.
Tweakie.CNC
Re: Just for fun.
Postby andre99 » Sat Dec 19, 2020 8:56 pm
Oke I will go and try it out when I have good result I will post right away.
Happy that you want help me.
andre99
Re: Just for fun.
Postby andre99 » Sun Dec 20, 2020 3:56 pm
I have made this today, in Uccnc laser plugin.
First I have take the picture en putt it true the filter website
Imag-r.com and there i putt it on 318 DPI and the filter NEW WOOD
I saved the file and load it in Uccnc laser plugin.
And this is my first result.
Thanks Tweakie.
andre99
