Hello everyone,
Some quick machine specs:
*Xzero CNC Predator Kit
*Tekno Electrospindle C4147 with external fan
https://www.damencnc.com/products/milli ... 31_32_GB_1
*Delta VFD 022E21A 220V w/ 100OHM Brake Resistor
https://www.damencnc.com/products/cnc-c ... _2222_GB_1
*Leadshine Easy Servo ES-MH23480 x3
http://www.leadshine.com/productdetail. ... ES-MH23480
*Leadshine Easy Servo Driver ES-DH1208 x3
http://www.leadshine.com/productdetail. ... =ES-DH1208
Control:
*UC300ETH w/ UB1 Breakout board
https://cnc4pc.com/uc300eth-ethernet-mo ... ler-b.html
http://www.cncroom.com/interface-cards/ub1
Software Side:
*Windows 7 PC
*The UC300ETH is communicating with the PC. I am able to ping it and everything is set up as per the UC300ETH manual.
*UB1 profile downloaded for UCCNC from CNCRoom.com and configured as per the UB1 manual regarding I/O, Axis, Spindle, Charge Pump, etc..
Experienced Problems:
*We are unable to jog the router using UCCNC. However, we are able to jog the easy servos manually via the Driver LED display.
*We are getting the following RED fault codes in the diagnostics menu within UCCNC
*Charge Pump1 - Flashing Red
*PWM Spindle - Solid Red
*All directional Axis pins are Offline
We commissioned a professional for assembly and wire-up of all the electronic components. Attached are photos of the cabinet itself and the UB1 board with status LED lights. It seems that the issue we are currently experiencing is beyond the scope of the builder or we have not communicated the issue clearly.
We suspect that the reason for unresponsive UCCNC input is because the CP pin is not wired up hence the flashing fault in the UCCNC diagnostics menu.
Any input is greatly appreciated. Thanks!
