Use profile after reload
Postby Makingtoothpicks » Tue Sep 20, 2016 11:08 pm
I had a problem. I had a computer crash. I am using a new computer and Windows 10 . I have it set up and running. No updates allowed . Everything is fine. I have one small problem. I do not have my profile on the desktop. There is a folder in the UCCNC folder with the name of the profile I created. With out having to redo everything is the a way to get my profile on the desktop.Now I have to start UCCNC wait for it to load then go to configuration and load My profile.
Thank You
Don
Makingtoothpicks
Re: Use profile after reload
Postby cncdrive » Wed Sep 21, 2016 10:45 am
Right click the UCCNC.exe and Create shortcut and then place that shortcut icon on your desktop.
If you running a different than the Default.pro profile then right click the shortcut icon and edit.
In the editor window set the target like this: C:\UCCNC\UCCNC.exe /p myprofilename
Ofcourse the path for you may be differnet depends on where you installed the software and the myprofilename is the name of your profile.
Postby Makingtoothpicks » Thu Sep 22, 2016 12:59 am
Thank you I will give that a try.
Don
Makingtoothpicks
