Home Slave axis
Home Slave axis
Postby Profoxcg » Mon Sep 04, 2017 8:04 pm
Hello Everyone,
I have purchased a second proximity sensor to be used for homing and I would like to installed it on the slave axis on my machine's Y Axis with the intention to have the machine square the grantry should it be needed.
I am currently only using one sensor on the "Master" side.
My "Slave" axis does not have any pin assignments for homing of limits. Is it just a matter of filing out the pin and port number to be able to do what I would like?
Thank you
Profoxcg
Re: Home Slave axis
Postby ger21 » Mon Sep 04, 2017 10:39 pm
Yes, just assign the Home port and pin numbers for the switch on the Slave axis, and it should work.
Re: Home Slave axis
Postby Profoxcg » Tue Sep 05, 2017 1:32 am
thank you, at that point I am guessing that the slave will not top until it gets the signal from the limit switch ? in other words,
it will keep going even if the master stopped.
Profoxcg
Re: Home Slave axis
Postby ger21 » Tue Sep 05, 2017 1:47 am
Yes, each side will move until it sees it's own switch.
Re: Home Slave axis
Postby Profoxcg » Tue Sep 05, 2017 3:48 am
great, thank you
Profoxcg
Users browsing this forum: Bing [Bot] and 13 guests
