Y homing actual speed (act. feed) differ from setting
Postby merrick » Sat Aug 26, 2017 3:56 pm
On 1.2042, I have the homing speed for long axis (Y) set at 120 (ipm) but I'm seing the feed rate DRO displaying 167. Is that normal?
merrick
Re: Y homing actual speed (act. feed) differ from setting
Postby cncdrive » Sun Aug 27, 2017 7:12 am
There are 2 homing speeds per axis, one for the upwards movement to the home switch and one is the downwards movement.
Verify that you comparing to the proper value.
Postby merrick » Sun Aug 27, 2017 5:45 pm
My Y axis has a slave (A). The homing forward speed set for both (Y and A) is 120. Upon executing the homing routine, the DRO indicate that the actual homing speed is 169.1. There was no F override at all.
merrick
Postby ger21 » Sun Aug 27, 2017 7:13 pm
I think it's a bug, and the DRO is displaying the blended speed, as if the X and Y were homing together.
At least the math for that adds up.
