UCCNC crashed with mach3 file with ignore unknown gcode
Postby merrick » Sun Aug 20, 2017 8:02 pm
I want to test out uccnc with a mach3 file that was generated in VCarve pro using mach3 pp. The UCCNC version is 1.2042. In the config, I set it to warn of unknown gcodes. After UCCNC pops up a warning msg asking if I want to continue, I clicked NO and the software just crash (stop responding). Shouldn't be just gracefully go back and let me change out for another file?
merrick
Re: UCCNC crashed with mach3 file with ignore unknown gcode
Postby cncdrive » Sun Aug 20, 2017 8:20 pm
I've just tested the unknown g-codes report and I do not see the problem, it just stops here without crashing.
You may want to post your g-code file to let us test.
Postby merrick » Sun Aug 20, 2017 9:13 pm
I could not post the file, the size is too big.
merrick
Postby cncdrive » Sun Aug 20, 2017 9:44 pm
Then:
1.) Try to cut the file and try to reproduce the issue with the smaller file and if you can then post it.
OR
2.) Upload it to somewhere, e.g. Googledrive, Onedrive, etc. and post the link.
Postby ger21 » Sun Aug 20, 2017 11:01 pm
Try zipping it.
Postby merrick » Sun Aug 20, 2017 11:57 pm
Attached please find the zip file
crash_uccnc.zip
(268.8 KiB) Downloaded 769 times
merrick
Postby dezsoe » Mon Aug 21, 2017 1:05 pm
merrick wrote:Attached please find the zip file
I tested your code with the warning enabled. I had no problem with answering either yes or no. Could you post your profile (.pro) file for checking?
Edit: I used version 1.2042 as you.
Postby merrick » Mon Aug 21, 2017 1:55 pm
Attached is my profile. It crashed on me every time.
CNCRP.pro
(31.67 KiB) Downloaded 827 times
merrick
Postby dezsoe » Mon Aug 21, 2017 3:25 pm
merrick wrote:Attached is my profile. It crashed on me every time.
Still nothing. Did you try it with the default screenset? As I see, you use a screenset called "Domino". I could not find anything about it on the internet, so I really don't have any idea. :(
Postby cncdrive » Mon Aug 21, 2017 3:39 pm
I have tried to run your code yesterday evening and I could not reproduce the crash, it works for me without any problems.
I went on Summer holiday this morning, will be back on next Monday only, so Dezsoe collegue can help you till that...
