I'm attaching a picture to this post.
You should check the Voltage with a multimeter between (I've marked the test points with light green color):
GND - point 1. : If there is no voltage here then you DC power input connection do not get in at all, maybe a lost connection or burnt up track on the PCB.
GND - point 2. : If there is no voltage here then the ferrite bead component whose pin is marked with point 2. is burnt. It is used like a fuse, it fuses out on heavy overcurrent.
GND - point 3. : If there is no voltage here then the reverse polarity protection diode whose pin is marked with point 3. is burnt.
GND - point 4. : If there is no voltage here then the 78l05 5Volts LDO is burnt and so it is not creating the 5Volts from the 12V input.
