Hello,
I recently switched over to Windows 10 from Windows 7. Right away I noticed UCCNC started lagging. I ran a small test program and everything worked fine at the time. Over the course of I few days UCCNC started to lock up when I would load a new program. I thought my post was throwing out a bit of code UCCNC didn't like so I stripped out every bit of code the software didn't need and then it would work for a short time and lock up. I downloaded and clean installed UCCNC and still locked up. Once this happened I then loaded the original "Test" program that ran fine, now started to lock up. I decided the issue was caused by upgrading to windows 10. I then reinstalled Windows 7 and since then everything seems to be working properly. Is this is a known issue? I read on an older post that there was a old security update that caused this but I read there was a workaround In a previous UCCNC update.
Thanks for your help
