I am use this future for plate alignment.
Operator set two points on the plate, then plugin calculate rotation angle and execute for example "G68X0Y0R3" code.
I am notice, that if the current XY position is not X0Y0, UCCNC make coordinate rotation and gantry move to the zero position (any time this position out from plate and in the Active code DRO I see for example |G68X-7.5Y59.5R7.2|).
Usually G68 just rotate coordinates, but not make any moves.
May be I am doing something wrong?
Please explain
Thank you!
