Charge Pump indication
Postby martin54 » Wed May 31, 2017 7:02 pm
I have a uc400EFT motion control card & I am running mach3 because I am still undecided about uccnc, I have never had a problem with mach3 personally but know that others have switched for one reason or another.
With uccnc when I enter the diagnostic screen the charge pump indicator is constantly flashing, doesn't seem to make any difference if I set it to active low or select charge pump always on. Did try a search on the forum but couldn't find an answer.
martin54
Re: Charge Pump indication
Postby dezsoe » Wed May 31, 2017 9:51 pm
Are you running UCCNC in demo mode? I tried it and in demo mode the indicator for charge pump does not work as it should, but with UC400 connected it works well.
Postby martin54 » Fri Jun 02, 2017 10:08 pm
Sorry about the slow reply, been away from the internet. No not running in demo mode, licenced software & UC400EHT motion control board.
It doesn't seem to affect the operation of the machine in any way that I can see but I am still a novice at this sort of thing so it would be very easy to miss something. :)
martin54
Users browsing this forum: Bing [Bot] and 22 guests
