UCR201 - Function Buttons for an ATC
Postby CNCnStuff » Sat Mar 15, 2025 8:54 am
Good morning,
I'm trying to identify the correct code to attribute the Tool Release button on the Run screen to a Function button on the USR201, but am having trouble finding the right one.
I have watched a YT video (https://www.youtube.com/watch?v=x1Lqqr9vZbo&t=223s) where the presenter used 510 (F4) and 511 (F5), but they didn't work (I appreciate they're for the M8 Flood button, but that was the suggestion!) so perhaps someone would be kind enough to tell me what codes I should use, please?
I can't find it in the Buttons_by_number document file, so is it even possible?
One thing I think may be affecting it is the confirmation pop-up window, when the on-screen button is pressed. Is this where my problem is?
Thank you.
Our lives are merely trees of possibilities
(Marc Bolan 1947-1977)
CNCnStuff
Re: UCR201 - Function Buttons for an ATC
Postby Fritz » Sun Mar 16, 2025 10:24 pm
I replied to this the other day but somehow managed to do it on the wrong thread. /facepalm
Let me try again.
510 and 511 switch the flood cooling on and off.
I'm only learning myself, but I'm guessing he just wired up the outputs to the tool release relay instead of a flood coolant relay.
A list of button numbers can be found in Buttons_by_number.htm file in the UCCNC/Documentation folder.
file:///C:/UCCNC/Documentation/Buttons_by_number.htm
Fritz
Postby CNCnStuff » Mon Mar 17, 2025 9:42 am
Fritz wrote:I replied to this the other day but somehow managed to do it on the wrong thread. /facepalm
That's the sort of thing I'd do..!
Thanks for the pointer, but I can't see any other reference to that button, unless it has a random name - or is actually 117 (M8 Toggle for the Flood button).
I guess I'll have to experiment a little :shock:
CNCnStuff
