Background color of Tool Path Screen
Postby George M » Sun Feb 16, 2025 2:38 pm
How do I get a black background on the Tool Path screen? I have set any color that should relate to it on the Appearance screen, but the background remains white.
Exactly what is the background called, and where (if not Appearance screen) would I find it?
Thank you
George M
DIY CNC Machine
UCCNC
UC300eth-LPT5
UCBB
George M
Re: Background color of Tool Path Screen
Postby cncdrive » Sun Feb 16, 2025 4:43 pm
It is the background color setting in the appearance menu, but after changing it you have to press the Apply settings button just like for everything in the UCCNC to validate the changes in the settings.
Postby George M » Mon Feb 17, 2025 9:40 pm
I have that set to black and did the apply and save. It has always been that way.
However it is not showing that.
I am using Gerry's screenset 2022 if that matters. I'm attaching screen shots
Thank you
George M
DIY CNC Machine
UCCNC
UC300eth-LPT5
UCBB
George M
Postby George M » Wed Feb 19, 2025 2:31 pm
Any advise here?
Thank you
George M
DIY CNC Machine
UCCNC
UC300eth-LPT5
UCBB
George M
Postby cncdrive » Wed Feb 19, 2025 4:11 pm
It works fine here, so I don't know what could be the problem.
Gerry can you test this please with your screenset?
Postby ger21 » Wed Feb 19, 2025 5:03 pm
I'll check this evening when I get home from work.
Postby ger21 » Wed Feb 19, 2025 11:49 pm
George,
If you click on the black square, does the color picker open up?
It works fine for me here, I can change the background to any color.
If you click the Edit Screen button, then click on the background colored square, does the screen editor look like this?
Postby George M » Thu Feb 20, 2025 2:13 pm
Thanks Gerry
I tried other colors and on the third time it started to show correctly. Maybe my old computer?
Anyway, now working correctly.
George
Thank you
George M
DIY CNC Machine
UCCNC
UC300eth-LPT5
UCBB
George M
