Probe pins
Probe pins
Postby danut1234 » Sat Feb 08, 2025 6:36 pm
Hi, i am working on a software that needs to probe some parts... and i have seen on the forum that the 2 probe pins sent with SetProbeSetting() are used at the same time. It would be nice if ProbeStart(int Axis, double ProbePos, double Speed, int ID); would have a parameter for what pin to listen, 1 or 2. My situation is that pin1 will always be activate before pin2 but i am interested to see only if pin2 is active. Now i am sending the probe setting before the probe operation starts and select the correct pin...
Best Regards,
danut1234
Re: Probe pins
Postby sabrina23 » Mon Feb 10, 2025 1:19 am
To use only Pin2 for probing in UCCNC, you should set `SetProbeSetting(2, true);` and `SetProbeSetting(1, false);` before calling `ProbeStart()`. This ensures Pin1 is ignored, and only Pin2 triggers the probe stop.
Slope Game
sabrina23
