Softlimit override
Softlimit override
Postby Sanji » Sat Jan 25, 2025 2:18 pm
Good day.
Is it possible to temporarily disable softlimits automatically when probing just like when Homing, the softlimits are ignored.
The reason is I want to place my fix probe outside of the softlimits.
Thank you always.
Sanji
Re: Softlimit override
Postby ger21 » Mon Jan 27, 2025 2:40 pm
You should be able to modify your probing macro to disable them, then re-enable them.
Postby Sanji » Wed Jan 29, 2025 5:29 am
Thank you for the response.
May I ask what is the code to enable and disable the softlimits so I can add it to my probing routine.
Sorry to ask but I cannot find the code in the manual or in the forum.
Thank you always.
Sanji
Postby jjude » Fri Jan 31, 2025 7:17 pm
As I recall, this is how
Soft limit off exec.Callbutton(519);
and again on exec.Callbutton(518);
jjude
Postby cncdrive » Fri Jan 31, 2025 10:50 pm
Yes, you can call the function code (buttonnumber) of the function you want (E.g. the softlimits).
You can check the UCCNC/Documentation folder, there is a list of the button numbers.
Postby Sanji » Mon Feb 03, 2025 12:26 am
Good day,
Thank you for all your help.
Thank you always.
Sanji
