H100 VFD
H100 VFD
Postby Sanji » Thu Jan 09, 2025 1:24 pm
Hi Good day,
I just recently installed AXBB-e motion control and UCCNC software but can`t get the spindle to turn.
The VFD gets the correct signal from the AXBB-e but the spindle won`t turn.
I measured the voltage from AO1/5V0 and it is 0V when Spindle Speed is 0 and 10.2V when spindle speed at maximum.
X1 forward (M3) connected to port 1 pin 3 and X2 reverse connected to port1 pin 4
If I just set the F001=0 (Control mode:Keyboard) I can turn the spindle by pressing the run button on the VFD then control the speed through UCCNC software.
But if I set the F001=1 (External control) the signal (correct frequency Hz) is being received by the VFD but the spindle is not turning on.
Has anyone experienced this kind of issue? How did you solved it?
Thank you always.
Sanji
Sanji
Re: H100 VFD
Postby cncdrive » Thu Jan 09, 2025 7:36 pm
Hi Sanji, please verify that for the M3 command the start input on the VFD should measure 0 Volts between the VFD ground and the input terminal when the M3 signal is active and it should go high level 10 to 24Volts when the M5 command is executed. (spindle turned off)
Re: H100 VFD
Postby Sanji » Sat Jan 11, 2025 1:53 am
Hi Good day,
I am sorry for the late reply.
I`m out of the shop I can`t verify the voltage now, when I get to the shop I will verify it.
I have a question regarding with the AXBB-e manual there is this (J1000 VFD) SC connected to 24V0, if you vae any idea what is the equivalent of this SC port into H100 VFD?
Thank you always.
Sanji
Sanji
Re: H100 VFD
Postby Sanji » Sun Jan 12, 2025 12:53 pm
Hi Good day.
I have already make it work. Thank you.
This is what I have done please correct if something is wrong.
Thank you always.
Sanji
Sanji
Users browsing this forum: Bing [Bot] and 25 guests
