Connecting AXBBE & Relay Module that uses a Signal Trigger
Postby poppyseeds » Wed Jun 12, 2024 9:35 am
I am trying to use this relay module to connect the COM and FWD together on my Nowforever VFD. Have I understood the wiring correctly in connecting the relay to AXBB E
poppyseeds
Re: Connecting AXBBE & Relay Module that uses a Signal Trigg
Postby cncdrive » Wed Jun 12, 2024 6:50 pm
Yes, the wiring looks fine.
Postby poppyseeds » Thu Jun 13, 2024 1:53 pm
cncdrive wrote:Yes, the wiring looks fine.
Thanks for confirming, i got the spindle working, hurray. The relay trigger jumper had to be set to Low, it was set to high.
Im not sure why that fixed it, but it did :D
poppyseeds
Postby cncdrive » Thu Jun 13, 2024 7:16 pm
That is because the Isolated outputs are N-channel mosfets (NPN), so they pull the signal low when the output is activated.
