UCCNC and W10 not starting
PostPosted: Mon May 27, 2024 8:52 am
by tom2019
Was working for years, after some time not using it, I try to start the program, nothing happens, no errors.
Remove it, install it again, same bahaviour, no errors not starting.
Using the utility and can see my network or use devices.
Any idea of where is the problem?
Re: UCCNC and W10 not starting
PostPosted: Mon Jun 03, 2024 7:38 pm
And the utility tool says OK if you test the connection?
PostPosted: Wed Jun 05, 2024 10:32 am
by tom2019
When I press Scan on the utility recognize the usb or the ethernet controller, whathever is connected.
Anyway here is not the problem, if not seen on the bus any controller program will start showing the demo controllers, but this never happens.
Is any way to trace or see what library or ther need to be installed or fails?
What microsoft runtime or other libraries are required?
PostPosted: Wed Jun 05, 2024 11:57 am
by mickecarlsson
Check your Event log in Windows 10. Try to start UCCNC, then look in Event log for errors.
PostPosted: Wed Jun 05, 2024 4:47 pm
by tom2019
Yes!!
Messages are in Spanish but it is clear more or less.
Error from UCCNC:
Aplicación: UCCNC.exe
Versión de Framework: v4.0.30319
Descripción: la aplicación solicitó la finalización del proceso a través de System.Environment.FailFast(mensaje de cadena).
Mensaje: Profiler detected
Pile:en System.Environment.FailFast(System.String)
Any solution for this?
PostPosted: Wed Jun 05, 2024 4:54 pm
by tom2019
Installing .NET 8.0 doesn´t solve the problem.
PostPosted: Wed Jun 05, 2024 7:44 pm
by tom2019
Installing .Net Framework 4.8.1 also no change.
PostPosted: Wed Jun 05, 2024 8:34 pm
UCCNC requires the .NET framework 4.0 and the Visual C++ redistributable 2008 package to run.
PostPosted: Thu Jun 06, 2024 9:54 am
by tom2019
No results...
Trying to install .NET framework 4.0 and I get a message from installer saying I have a modern version so no need to install it.
Visual C++ redistributable 2008, I got a message saying reinstall or remove (so it is already installed), reinstall just in case, UCCNC still not starting.
PostPosted: Fri Jun 07, 2024 5:55 pm
The UCCNC requires nothing else, so I don't know why is it not running if both prerequirements are installed.
Try to repair the .net framework and the C++ redist package, maybe it has a problem.
